Joined: Thu Dec 04, 2008 9:51 pm Posts: 128 Location: Freedom 40 Cat Ketch, Hull #61, Corpus Christi, TX
Mike
Vaseline is a petroleum based product. Petroleum based products & rubber are not a good mix. (This is why they tell you not to use Vaseline or mineral oil with condoms... the results may be quicker and more expensive, but the concept is the same).
Little by little, you're destroying your gaskets by gooping with Vaseline. The proof of that is in the "black" that you see in the "goop" when you open the hatch or port, particularly if it seems to have "migrated" into the non-glass portlight itself.
It's just like having a freshly waxed hull...you don't see the oxidized gel coat running down the scuppers because you're "washing wax" rather than scrubbing off gel coat. If you're "seeing black", then it's because there's rubber IN it.
There are other products which will accomplish the same thing...silicone grease for example. More expensive, but not that expensive...and you don't have to use it every time you wash down the boat or open a hatch.
