installation Webasto ST 2000 on freedom 35
would appreciate tips and hints on how to install webasto ST 200 diesel heater on freedom 35. dholtkamp@aol.com
Re: installation Webasto ST 2000 on freedom 35
I am not sure of the layout onboard F35 but on my 1986 F36 I have Espar diesel heater installed in the Port locker just under the deck about three feet aft of the bulkhead between galley and the locker. Hot air ducting is piped alomg the Port side behind lockers etc, with two branches leading to main cabin, one to the head and one to the vee berth. I do not have the branch leading to the Starboard side quarter berth. This was original layout, although I may add a branch to the quarter berth. Exhaust pipe is lead aft about 1.5 ft above water line and diesel dosing pump is situated in teh engine compartment, pumping fuel to the heater via small diameter / capillary tube. Control box with all relays and fuses is in te same locker and power switch connected to the thermostat is in the main cabin.
I hope this helps.
I hope this helps.
1986 F36/38
s/v Mirage
s/v Mirage
