seacock for freedom32
Postby Equinox » Mon May 20, 2013 3:33 pm
I am a new owner of a freedom 32. I have 2 frozen seacocks located on the starboard side. One is for the toilet discharge and the other is for water intake. Both seacocks are located in a very inaccessible location. Does any body know how to improve such design? Maybe relocate them or attach metal piping through the hull and put a valve in a better location?
Ed
Equinox
Re: seacock for freedom32
Postby rbrown739 » Mon May 20, 2013 8:43 pm
I installed a removable, circular, plastic port light just off the deck so I could reach back and operate those two valves. Works OK.
Bob
rbrown739
Postby Equinox » Thu May 23, 2013 3:31 pm
Thank you for your advice. I will consider it.
Ed
Equinox
Postby joseph.syc » Wed May 29, 2013 11:51 am
Just to second Bob's solution, the PO did that on my F32 as well. Makes my monthly exercise of those seacocks easier than it would be otherwise.
Joseph
S/V Timbuktu
Freedom 32 - Hoyt
Hull #43
joseph.syc
Return to Plumbing
