Joined: Sun Dec 07, 2008 2:41 pm Posts: 16 Location: Freedom 36 #71 - Wakefield, RI
Many years ago, I formed stainless steel tubing into the required shape for a bow pulpit using a rented tubing bender. These tools are used by electricians to bend metal conduit. Be sure and cover the tool with a layer of tape to prevent scratching the tubing.
After the bows are installed, use a strip of tape along the boat centerline to support the bows in their proper position and make paper templates for each section of the dodger or bimini. Then cut out the material and stitch away.
_________________ Dwight Escalera F36-71 Wakefield, RI
