F25 Wing Mast Wiring
lowe
Post by lowe »
How does the wiring go thru the wing mast?
1982 25ft wing mast with 7hp Yanmar diesel
yarrow
Re: F25 Wing Mast Wiring
Post by yarrow »
mine is a straight cable 2 wires in 1 layer of insulation, and it hangs loose out of the bottom of the mast. I've heard it helps to add items to wires to keep from rattling inside the tube.
95' B3 I-14
providence RI
