FreedomYachts.org
Freedom Yachts Sailboat Discussions
It is currently Thu Sep 09, 2010 6:59 am
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: KIWIPROP FOR THATBOAT GUY
PostPosted: Thu Mar 04, 2010 4:27 am
Offline
GEORGE,
A KIWIPROP JUST CAME UP ON TRADEME ONLINE AUCTION. ITS AT THE OTHER END OF THE COUNTRY FROM ME SO I CAN'T INSPECT FOR YOU. LINK IS http://www.trademe.co.nz/Trade-Me-Motor ... 620306.htm
YOU CAN EMAIL ME ON ptpc@clear.net.nz IF I CAN BE OF ASSISTANCE. (OUR HOME COMPUTER IS AWAY BEING FIXED)
BEST REGARDS,
_________________
Mike Holibar
Lyttelton
New Zealand
Top
 Profile
 Post subject: Re: KIWIPROP FOR THATBOAT GUY
PostPosted: Sat Mar 06, 2010 8:41 pm
Offline
Mike that's awesome and we want that prop. Unfortunately I'm not able to register to the auction site because I don't have a kiwi phone number? I've also emailed this to you. Any suggestions?
Thanks so much for thinking of us.
_________________
George and Kerri Huffman S/V Marquesa Freedom 40 CC CK George and Kerri.ComImage
Top
 Profile
PostPosted: Thu Mar 11, 2010 6:49 pm
Offline
I can't believe I let that get away. I don't know what I was thinking but I originally thought I had until tomorrow. I went to sign up on the auction site just now and saw that I missed out. Arrrrgh!
_________________
Top
 Profile
PostPosted: Wed Mar 24, 2010 6:16 pm
Offline
Hey George,
I am also thinking of getting a Kiwiprop for my F-40 CK. Do you know if there is sufficione clearance for the prop in the hull-rudder opening? Kiwi's site mentions from 16.5 to 18.5" diameter depending on transmission.
I meant to dive and measure it last week-end, but the water is still a little chilly (even in Georgia).
Any ideas in sizing? (perkins 4-108 and Hurt/ZF 12M tranny, about 2:1 A and 2:7 B) Std F-40, I suppose).
Cheers,
Alex
Top
 Profile
PostPosted: Thu Mar 25, 2010 11:02 am
Offline
Hey Alex,
The answer is: I don't know. I've been told that they do fit. We will haul out later this spring and I'll know then but right now the water temp is still 50 here! :shock: What propeller are you using now if I might ask?
_________________
Top
 Profile
PostPosted: Thu Mar 25, 2010 5:05 pm
Offline
Hi,
The boat has the fixed two blade prop that came with it. I am not sure of diameter or pitch. It feels a bit underpropped. I get about 5 - 5.5 kts @ 2800 rmp. After that the engine will rev up to 3800 or more (and aboput 7 kts) but feels underloaded.
I mostly want the folder for performance sailing though.
I may try to check it out this week-end.
Cheers,
Alex
Top
 Profile
PostPosted: Sun Mar 28, 2010 4:55 pm
Offline
Ok! I'm still not sure the kiwiprop will fit on the F-40 CK. I took the plunge yesterday. Not sure if it was great idea that water was COOLD! So I only had time to make some very gross measurements with my wife's sewing measuring tape.
The opening from top to bottom is about 26" so no problem there. From the cutlass bearing, along the shaft, about 10.5" to the leading edge of the rudder (take with a grain of salt, these are really gross measurements. I had a windsurfing wet suit trying to float me back up and it was freezing cold).
Kiwiprop calls for 8.25" clearance:
http://www.kiwiprop.us/space-requirement.htm
I am concerned that since the rudder and shaft are not at 90 deg angle the lower blade may be too close when feathered.
I guess some more measuring is in order.
Does anybody know of an F-40 with a feathering or folding prop?
Cheers,
alex
Top
 Profile
PostPosted: Mon Mar 29, 2010 4:19 am
Offline
Alex,
By nature of the force of gravity, with a three bladed feathering prop, one blade will stick up and two blades will hang down to port and starboard. If the blades can pass the rudder in the feathered position, there's not much to worry about. If the prop is working, the distance to the rudder is much more critical.
_________________
Top
 Profile
PostPosted: Mon Mar 29, 2010 5:08 pm
Offline
Hmmm! Looking at the picture above, I am not sure there is enough room for a puller for the prop and just barely enough for the prop itself to come out.
Does anybody know if the rudder needs to come off to replace props?
(I know it should be obvious, but all my other boats had fin keels and spade rudders :oops: )
Cheers,
alex
Top
 Profile
PostPosted: Sun Apr 11, 2010 7:02 pm
Offline
I've had our prop off and shaft out without removing the rudder.
_________________
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
