FreedomYachts.org
Freedom Yachts Sailboat Discussions
It is currently Mon Sep 06, 2010 10:42 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: fuel oil in the bilge -- F38
PostPosted: Sun Jul 18, 2010 7:22 pm
Offline
Noticed small amount in the bilge, doesn't seem to be coming from the engine as the pan beneath the engine is fairly free of fuel.
Several weeks ago I did have some leakage from the secondary fuel filter but I assume that all of that oil did go into the pan and I cleaned it up with engine diapers.
Could it have gotten below that pan and gotten into the bilge? I hope so, otherwise I guess I have to investigate a fuel tank leak. Have no idea how to find that leak other than going for to Paul Dennis and leaving some boat bucks (although in fairness he is always reasonable for the service received).
Any thoughts, suggestions would be appreciated.
_________________
Ed Reiss
Being There
F38 - #154
out of Bristol, RI
Top
 Profile
 Post subject: Re: fuel oil in the bilge -- F38
PostPosted: Mon Jul 19, 2010 6:22 am
Offline
I would thoroughly clean the bilge and see if it reoccurs. If it does, then you've got a problem. If not, it's leftover from your past exercise.
_________________
Top
 Profile
PostPosted: Mon Jul 19, 2010 9:40 am
Offline
I'm with Geoff on this.
_________________
George and Kerri Huffman S/V Marquesa Freedom 40 CC CK George and Kerri.ComImage
Top
 Profile
PostPosted: Tue Jul 27, 2010 9:38 pm
Offline
I've had some leaking from several of the banjo bolts on metal fuel lines - need occasional snugging.
_________________
Sailmon
S/V Her Diamond
1991 Freedom 38
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
