Hi,
I have recently purchased a british 35 cat ketch which was contverted to contventional track and boom with rod kick. I am considering converting back to wishbone rigging. My queston is where can I find a wishbone boom? Is there anyone in Europe who makes them?
Wishbone boom
Wishbone boom
UK F35- Cat Ketch
S/Y India
Limhman Sweden
S/Y India
Limhman Sweden
Re: Wishbone boom
I think they were originally made in the UK by Proctor Spars, now long defunct. I could get you some measurements from mine, if you wish? I understand the original Hoyt F40 booms were wooden, and making new ones by laminating suitable wood might be the easiest and cheapest route for a one-off project. Otherwise, find some engineer who can bend and weld 38mm diameter aluminium tube. The clew ends of mine are held together by a plate with two short stubs which fit into the tube ends, and then riveted. This allows the ends to be separated and sprung apart to get the boom on without lifting it over the mast (or the mast over it).
Gerald Freshwater
Gerald Freshwater
Re: Wishbone boom
Thanks for your reply Gerald. I have considered making the boom in wood, as the original. Please do send the measurements of your booms and could you also send pictures of the choker set-up and end-plate?
Shae
Shae
