Guys,
Yesterday I completed installing my Hydrovane. Mounting the top bracket through the resin and glass filler block was fairly easy; I could access the inside of the transom via the cockpit locker. And since I lost 15 kgs of body weight these last few months, I was more agile and comfortable in that cramped space. Installing the bottom A- frame brackets presented a problem however; I could not get to the inside transom at the desired locations. So I moved up the bracket and shoved the genset partially out its box to get to the inside transom:
Here is the completed installation:
Here's a view on the vane head control line. Still have to find out if there's not too much friction in it. I led the line to the side of the deck close to the control unit of the autopilot, so I can set both steering systems in sync with each other.
Many thanks to Hans Hansen, who offered his two year old Hydrovane for sale to me.
