Continuation ..........
Here is an end on shot of the fitting clearly showing how badly blocked it had become.
File comment: Water Injector - End On
I decided that just cleaning the fitting was not enough. Apparently, some Yanmar engines with this water injector require the fitting removed and cleaned frequently, sometimes more than once a year!! It is a simple fix and not difficult to address as 'Annual Maintenance' but after contemplating the issue, I decided to replace the 90 degree fitting with a straight fitting as shown here hoping for a permanent fix.
File comment: Water Injector - Straight Version
Incidentally, the hose connected to the fitting is from a siphon break that is mounted high up under the galley sink and you can see the input end to the siphon break on the back of the heat exchanger.
Well, I ran the engine in gear at the dock for some 20 minutes which would have normally caused the overheat alarm to sound. Then after a trip to the marina pump-out station, leaving the engine running while pumping, I took a quick trip out into Chesapeake Bay. Went out about a mile or so out of Little Creek without any alarms, so on the return trip I opened the throttles and made 3,400 RPM's on the run in. Hooray, no alarms and no exhaust smoke It seems 'Magic' may be a less over-propped than I originally thought and is no longer on my list of 'things-to-do'.
Have I achieved a permanent fix? Time will tell.
This is a very easy fix, the cost, if only cleaning the elbow is nothing and takes between 30 minutes and an hour.
Incidentally, the corrosion that is visible is predominantly on the rear of the engine and has been caused by the siphon break that spits raw water when the engine starts and stops as water flow starts and stops through the raw water circuit. A 'splash guard' is on the 'to-do' list to prevent the engine getting splashed. The engine will be 'pulled' in the spring for new mounts, de-rusting and paint.
Robert
