F21 spinnaker pole diameter
Postby Jesse » Sat Jul 07, 2018 6:51 am
Hi all,
I have seen a few posts about the gun mount rig, but I am still looking for the diameter of the pole on the F21. I have the gun mount but need to make the pole. I measured the inner diameter of the gun mount sleeve at 3.25 inches. I can get aluminum tube stock in 3.25 and 3.00 inch outer diameter. I assume I will need to use 3.00 OD to allow clearance for the pole to slide through the sleeve, but I also don't want a lot of play and I know there is some measurement error in my measurement. Can anyone tell me the outer diameter of their spinnaker pole on the F21? Thanks in advance.
Best wishes
Jesse
Jesse
Re: F21 spinnaker pole diameter
Postby hkowalczyk » Tue Jul 10, 2018 12:13 pm
The OD of the pole is 3 inches. Remember there is a liner in the gunmount that will take up some of that space.
hkowalczyk
Postby Jesse » Mon Jul 23, 2018 11:07 am
Thank you so much for the info.
Best wishes
Jesse
Jesse
