Eye and hook for companionway stairs on a F-30
lee
Post by lee »
On my F-30 I have a hook and eye that holds the companionway stairs to the bulkhead. The hooks broke I replaced them from a marine hardware site. The new hooks don't bend in at the end of the hook, the result being that with vibration from people using the stairs the hooks occasionally come undone, leading the stairs to come out from under you as you walk down. (I have the imprint of the engine pulleys on the back of my favorite shirt from cracking my back on them) I tried to bend one of the hook ends in and it broke. Looking for a source for better hooks or ideally another solution to this problem. Currently I have large zip ties on them but it's a pain when I have to access the engine.
Lee
Tricia
Re: Eye and hook for companionway stairs on a F-30
Post by Tricia »
The previous owner of my boat drilled small holes in the ends of the hooks and threaded split rings through them. Still a bit fiddly, but secure.
drcscruggs
Post by drcscruggs »
https://www.zoro.com/whitecap-cabin-doo ... /G4553135/
I found this online and thought these might be worth considering.
Best
dwight
Contact:
Post by dwight »
Just because a hook and eye was there before doesn't mean that it is the best choice.
From your description I would consider the Sea Dog Anti-Rattle Latch from Wholesale Marine of the Flexible T-handle Latches from Fisheries Supply.
Other options:
AttwoodMarine.com
WhitewaterMH.com
MarineHardware.com
BoatOutfitteres.com
FisheriesSupply.com
JamestownDistributors.com
Dwight Escalera
Accredited Marine Surveyor, SAMS #1024
former engineer at Freedom Yachts
former owner F36-71
Wakefield, RI
lee
Post by lee »
Thank you guys, some great ideas here. I'm going to order a sea dog latch and see how robust it looks. Love having options!
