Mast Headlight bulb
philipl
Mast Headlight bulb
Post by philipl »
Does anyone know the type of bulb used in a masthead light on an 1990 F38. I changed it once before and noticed that it was a low profile bulb. The one I installed was standard and touched the top of the glass bulb ( and burned out pretty quick, as a result).
Philip Leahy
F-38 ex Manchester, MA.
mrleinweber
Re: Mast Headlight bulb
Post by mrleinweber »
Not sure of the bulb size but the better thing to do is replace with an LED - optimally a tri-color mast head light which is awesome when sailing at night
philipl
Post by philipl »
Good idea. Thank you. Mast is coming out this winter so I will get a chance to do that.
Philip Leahy
