Quantum 2 Radar for F28
Posted: Sun Jun 27, 2021 1:44 pm
by inevitablef28
Hello Freedom Friends! I have a 1987 Freedom F28 and am installing a Raymarine Quantum 2 radar to a post on the port side of the boat at the transom/rear of the cockpit. At what height above the deck should the radar be installed that will provide the optimum performance? Thank you for your advice in advance. Ken Woodward of the F28 sailing sloop "Inevitable".
Re: Quantum 2 Radar for F28
Posted: Sun Jun 27, 2021 5:47 pm
by GeoffSchultz
High enough so that the beam doesn't hit the boom, even when running downwind and the boom isn't parallel with the water.
Posted: Mon Jun 28, 2021 4:09 am
by inevitablef28
Thank you Geoff.
Posted: Mon Jun 28, 2021 4:36 am
by walterg
Hi Ken, hoping you can post pics/suggestions on your radar pole install when it's done....planning to do the same thing on my F28. thanks,
Walter
Posted: Mon Jun 28, 2021 4:33 pm
by Salacia
I've used this Edson tower for 10 years with success. It wasn't a major install. Edson part #674.
Posted: Mon Jun 28, 2021 5:21 pm
by GeoffSchultz
Here are some photos of my radar installation, which is on a 40/40, and probably overkill for a F28, but you have to think about the forces that a radar on a pole will generate if you're pounding into a seaway. The photo of the boom and radar isn't the greatest, but I don't have many from an angle where you can see both at eye level. Note, that this is my old radar pole and the newer one is higher, as this one was too low. I think that I probably added a foot. Also, note that there is a connection from the radar mast to the top railing to add stability.
- 20090522_154252.jpg (82.45 KiB) Viewed 5951 times
- 20180416_114730.jpg (46.77 KiB) Viewed 5951 times
The attachment 20180416_114730.jpg is no longer available
