If you're like me and curse every time that you have to change your impeller, I just (hey, I've *only* owned BlueJacket for 23 years...) found this impeller puller for a Yanmar 3JH motor. It is part #129671-92110. This may fit other impellers. s
BlueJacket has been stuck in Guatemala for the past 2 years and hasn't moved due to Covid, so I know that the impeller won't want to budge. I hope that this makes the job easier! If this makes the job as easy as it appears, it will be worth every penny of the $27 that it costs.
Impeller puller for Yanmar 3JH series
