I was running my engine at the dock yesterday, and a neighbor pointed out that water was exiting in two different places: the exhaust port, and what turned out to be the port side cockpit drain. I had never noticed this before. I soon discovered that the hose that runs from the seawater outlet on the heat exchanger to the mixing elbow has a T in it, with a hose that runs back through the cockpit locker to the top of the port side cockpit drain.
From what I can tell, Yanmar's design has the hose going straight from the heat exchanger to the exhaust elbow. I had always assumed that hose was a siphon break or something, but it doesn't make much sense if it's filled with engine water. Does anyone else have this on their engine?
Yanmar 3GM30F exhaust water plumbing
- RadioZephyr
Re: Yanmar 3GM30F exhaust water plumbing
Yes I have a similar arrangement on my 36 except the tee is much further up under the engine compartment and the hose and fitting going to the cockpit drain is much smaller. Always thought of it as a siphon break and never really got a lot of water out of it. If you think about it it is a good check on the exhaust elbow ability to pass water. The more restriction in the exhaust elbow the more water discharged out the tee. When was the last time the exhaust elbow was replaced? FYI - because you are pumping water out the exhaust is not necessarily an indication your exhaust elbow is good. I found that out this year when out of principle I replaced mine. The water passage was completely clear but the engine exhaust passage was so blocked I could just about see light passing though it. A quarter inch thick rod wouldn't even pass through. Mine was the original from 1986.
Rich Fontaine
s/v Liberte
Freedom 36, 1986
Portsmouth, RI
s/v Liberte
Freedom 36, 1986
Portsmouth, RI
- RadioZephyr
Hey Rich,
Glad to hear I'm not the only one with this setup! As you can see in the picture, the screw that's supposed to be supporting the T connector isn't actually screwed into anything, so it's just been hanging there for a while (at least since I bought the boat). Last night I mounted the T connector as high on the wall as it would go, but as you can see from the attached photo, water was still going through it. The mixing elbow looks pretty new, so I've always assumed it was recently replaced. I won't know for sure until I crack it open and take a look
- IMG_1491.jpg (120.75 KiB) Viewed 7591 times
Josh,
We met at the marine store earlier this week. I told a mechanic about your exhaust. He said direct drive engines stream exhaust water thru the prop below water and have a small 'tell tale' stream to let the captain know the exhaust is pumping. That seems to be w hat you have. Your engine was probably intended for a direct drive installation and somehow goto redirected.
If it is annoying, change the elbow. You will need to one of these years anyway.
best of luck,
best of luck,
Stephen Lee
Salacia
F35 Pedrick
Marblehead MA and Rockland ME
Salacia
F35 Pedrick
- RadioZephyr
Hey Stephen,
Good meeting you the other day! I'm a little skeptical, because I can't imagine how exhaust water could be streaming through my prop. It also doesn't seem like it would be a "telltale," as the outgoing water can't be seen from the cockpit. The main exhaust hose is routed to the port side by the waterline, just aft of the wheel, and it can be observed by looking over the side.
I'm planning to replace the exhaust elbow (eventually), and I guess I'll see what it looks like at that point.
What I was trying to say is direct drivie or sail drive systems exhaust thru the prop. We do not have sail drive systems. That is why there is confusion on your exhaust. Your engine was originally built for a sail drive boat and got redirected at TPI, where Freedoms were built.
If still confused, give me a call.
Stephen
Stephen
Stephen Lee
Salacia
F35 Pedrick
Salacia
F35 Pedrick
Stephen
Stephen
Stephen Lee
Salacia
F35 Pedrick
Salacia
F35 Pedrick
- RadioZephyr
Ahh, ok. I'll have to look into that.
