Camber Spar rigging
lee
Camber Spar rigging
Post by lee »
I just rigged my F30 for the season. I noticed there is a grommet on the luff of jib at the camber-spar pocket. Does the bolt that holds the wheel on the camber spar go through this grommet?
RadioZephyr
Re: Camber Spar rigging
Post by RadioZephyr »
Yes. Mine came with fender washers instead of the regular sized ones, and an additional pair so there's a washer on either side of the sail. On my setup it goes as follows: bolt head, fender washer, sail, fender washer, stainless clip, camberspar clevis, camberspar sheave/forestay, camberspar clevis, stainless clip, fender washer, sail, fender washer, nyloc nut.
Here's an illustration:
From the Camberspar brochure
Front end fitting.jpg (156.83 KiB) Viewed 2431 times
Josh
Sunset Spy
F38, Hull #152
Boston, MA
lee
Post by lee »
Thank you so much! Exactly what was needed!
jlodolce
Post by jlodolce »
F 40/40: My setup is the same except only two washers, one between the bolt head and the sail grommet and the other between the nut and the sail grommet. I always keep a string tied to the stainless clip, since they have an affinity for the water. The camberspar is always a struggle to install in the spring,but I find it is easier to install with the jib almost all the way up.
Jim Lo Dolce
Lo Dolce Vita VII
Freedom 40/40 #16 1995
