Hey folks,
it looks like I am starting down the path of moving away from the roller furler that my boat came with and installing a camber spar set up. I am in the process of purchasing the actual spar (thanks to Al Jacobs). So now I need a sail. Anyone have a camber spar sail for a F40/40 that is in reasonable shape sitting in their garage?
Or how about a sail design for one, so when I go to get one made I have something to hand off to a sail maker? Or along those lines, do you think that there is any chance of modifying my self tacking roller furler sail to be a camber spar sail? Obviously adding hanks is the easy part, what else needs to happen? A pocket for the spar. But is the sail shape significantly different?
Thanks!
Changing from Roller Furler to Camber Spar
Tony
Re: Changing from Roller Furler to Camber Spar
Hi Tony, on my F21, the self-tacking jib uses a metal wishbone attached to the clew and again at a right angles to the luff. It just clears the mast and is sheeted to the base of the mast so the sheet angle to the clew is extreme but it seems to work OK. The length of the frame is not adjustable and gives the jib maybe 5-10% camber, see old pic attached from previous owner. You can see leeward side of the wishbone frame.
- IMG_0538.jpeg (84.45 KiB) Viewed 3952 times
Thanks Newt2u... actually looking more for a template for a sail for a 40/40 designed with the camber spar.
Tony
OK now I have come accross a new stumbling block in this project. Shipping a 12 foot camberspar accross country seems to be problematic? Has any one done this before? Any thoughts? Already tried UPS/Fedex. They want a crate built around it. I can't really make that happen from the opposite coast.
Tony
The best suited option would be to ship this shrink wrapped on to two pallets. They can pick it up and possibly tie the spar down to a pallet. I used R+L Carriers before and they were both, quality service and affordable for a trucking company that handles any type of freight: https://www.rlcarriers.com/TonyB wrote: ↑Fri Sep 04, 2020 1:14 pmOK now I have come accross a new stumbling block in this project. Shipping a 12 foot camberspar accross country seems to be problematic? Has any one done this before? Any thoughts? Already tried UPS/Fedex. They want a crate built around it. I can't really make that happen from the opposite coast.
S/Y Star Wake
87' Freedom 30
Hull # 75
Cortez, FL
87' Freedom 30
Hull # 75
Cortez, FL
I once shipped a 13 ft spinnaker pole across the US From NC to San Francisco and had to use a motor carrier. UPS, FEDEX Etc wanted nothing to do with it.
Did you have to crate it? Trying to figure out if maybe I put it in a PVC tube that would work.
Tony
You can try something like Uship. com. I've had good luck. But pay attention to the ratings of the carriers. Also, I think at this time of the year you have boats being shipped East to West, so some boat transporter may be an option.
Best of luck!
Best of luck!
Thanks Bad. I did ask for a quote on Uship and the quotes I got were very expensive. Will keep looking for options.
Tony
Tony
Tony
- GeoffSchultz
I wonder why they couldn't just wrap the camber spar heavily with sill insulation and then with plastic wrap and just ship it that way.
