F35 asymmetrical
Camino
F35 asymmetrical
Post by Camino »
Re: F35 (P) - is the usual phrf for this boat 144? What are people using? And is running a fractional asymmetrical spinnaker effective?
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
Salacia
Re: F35 asymmetrical
Post by Salacia »
My PHRF New England certificate is 150 racing/spinnaker and 162 cruising/non-spinnaker. That said, their web site says a Freedom 35 wk rates 144.
I've got an asymmetrical but I've only used it cruising
F35 asymmetrical.jpg (23.01 KiB) Viewed 2684 times
Stephen Lee
Salacia
F35 Pedrick
Marblehead MA and Rockland ME
Camino
Post by Camino »
Ah perfect! Is your spinnaker fractional or masthead and whichever does it draw well enough with the big main? (From the pic it looks fractional) - I'm interested in a top down furler , fractional, but don't know what size asym to use - I'll stick with ONE. Where do you attach the tack of your asymmetrical?
Im not getting any response on the asymmetrical advantage questions - so you all out there with Pedrick 35's - do you fly a spinnaker or asymmetrical with your main up and do you get downwind push that is worthwhile for the outlay of moolaw needed for the rig set up? Help here please. Thanks.
Tom and Stephanie
1999. Wing Keel 5’
Emery Cove, CA
