Ice Box Drain
psych
Ice Box Drain
Post by psych »
F30 Ice Box not draining. Can't find access to where it T's into drain hose. Any suggestions? Thanks.
drcscruggs
Re: Ice Box Drain
Post by drcscruggs »
FWIW, you might try a blast of compressed air to clean out. The only issue there is if it cut off (valve closed). Then of course a blast of pressure would not be good. I realize that this doesn't help you find the hose, sorry. best
Tricia
Re: Ice Box Drain
Post by Tricia »
Mine drains into the bilge. Sometimes a small plunger working the icebox drain works. Other times I've put the end of a small hand pump/bilge pump into the end of the hose and used suction to pull the blockage through.
psych
Re: Ice Box Drain
Post by psych »
Thanks for all your help. Problem solved. It does indeed drain into bilge not sink drain hose. Previous owner capped off drain hose.
wcwcwc
Re: Ice Box Drain
Post by wcwcwc »
My F36 came to me with the icebox draining into the bilge. I soon sealed it and pumped the ice box into the sink with a small pump. This reduced the smells from food particles being flushed into bilge.
Bill Cormack
