engine sizing for an F28 ck Hoyt
seadago
Re: engine sizing for an F28 ck Hoyt
Post by seadago »
andygc wrote:Rafael
Here's my FeatherStream with the flat anode. No modification to the rudder needed.
Regards
Andy
Many thanks Andy. This is very useful! Actually, I was looking at the prop this very afternoon (under the rain!) And taking measurements. Will get in touch with Darglow again and review options.
The boat is on the hard in Brest at the moment. I may have to take the engine out. The mounting bolts have worked themselves loose form the grp cradle. Probably need to be cemented in again. Then would be a good time to change the prop and (perhaps) upgrade the engine too. I don't know how easy/hard would be to do that here in France, but needs to be done!
Thanks again
Rafa
Rafa
Rafael
s/v Nausikaa
SSR 30570, sail GBR 4619L
andygc
Post by andygc »
The only wrinkle is that you have to take the rudder off to change the prop - but not to change the anode! ;)
Feronia
River Exe, Devon
CrazyRU
Post by CrazyRU »
I have original yanmar 2qm15 13 hp motor.
I have no problem to cruise at 5.5 knots with max just over 6 knots in ideal conditions.
Not sure about prop size, it is two blade, I believe original one.
CR
VeloFellow
Post by VeloFellow »
Clave' s original volvo transmission gave up, an inability to repair led to repower. Beta more expensive here,and although I liked it, we went with Yanmar 2ym15. Higher rpm just takes getting used to. Spinning 16 inch two blade. Flat water 5.5 knots. Fat heavy boat with windage could use more power but I use the engine to get out of canals and no wind. We have hit 9 knots sailing but often moving at 4-6 knots. Plan to sail soon.
Mike
s/v Clave'
1981Freedom 28 #112
Currently sailing Tampa Bay
yanmar 2ym15 2blade prop
