In the process of restoring the M 28, mostly refinishing or replacing the badly water damaged interior, which sat for 8 yrs with water over the floorboards. otherwise sails and engine are in excellent condition.
However, I can make no sense of the way the reefing system is rigged. It has been changed from the original single line system. Does anyone have a diagram of it? it isn't included in the owners manual.
Also, I have the gun mount bow pulpit, but nothing else, so I'm looking for the rest, or drawings,
Thanks, John
freedom M28
- RadioZephyr
Re: freedom M28
What kind of boom is it? If it’s an Isomat, it may have “single line reefing,” and there is a separate section of diagrams and instructions that were included with the later owner’s manuals. It’s a somewhat complicated setup, but it works well if you set it up right and maintain the blocks that are inside the boom. If it’s a Kenyon boom, it should just be regular slab reefing.
Josh
Sunset Spy
F38, Hull #152
Boston, MA
Sunset Spy
F38, Hull #152
Boston, MA
Re: freedom M28
This shows the setup and running rigging for the gunmount on the F21.
- A7017A4B-8CE6-4C00-A71B-A355206BDD4E.jpeg (2.04 MiB) Viewed 2232 times
Rockin - F21 twin drop keels - located Milford Haven, Wales
Re: freedom M28
It must be a Kenyon, which makes some sense,though I can see rigging it single line, like a H 35, which is a simpler rig. Thanks for the input, John
Re: freedom M28
I am new to this forum, and the new owner of a Freedom 28, so I have some newbie questions. When one refers to an M28, are they referring to Mull design? That is what I have . I was unaware there were two types of booms used in production. Mine is stored on the cabin at the moment, but would really like to know which one it is.
I have also looked for an owners manual on this forum. Does anyone know where I might find that? If it is here.
